I bought my computer in 2006 it is a Gateway 5474 came with a Asus G86-GW. I've been looking for hours and hours for a manual for this thing or even a manual for something similar with no luck.
Okay my problem is the card was failing on me so I pulled it out, It took a little force to get out then I noticed it had a cable pluged into it. I don't know if it was unplugged or if I unplugged it when pulling it out.
I noticed when I had the card out it has some bad capacitors, so I am going to replace the bad caps and reinstall.
Could someone please tell me what this cable is and if its needed I have no clue, maybe a cable for sli?
heres a pic
heres a pic
