1 - 8 of 8 Posts
hey people i just added a second monitor to my setup and the nvidia control panel is not coming up. i reinstalled the drivers correctly and still nothing please help
Did you use a driver sweeper software to clean all traces of previous driver?
Does the Device Manager show two monitors attached? Any exclamation mark there?
yes i used driver sweeper to clean all the traces and yes it shows the two monitors attached and there is no mark i dont know whats happening
3DFX User
Or open it from you control panel instead of right clicking.
Try setting it to display everything on your main monitor to see if it comes up?
Not new to Overclock.net
When you used Driver Sweeper, did you do it like this?
  1. Uninstall the NVIDIA Display Driver from the Programs and Features control panel.
  2. Reboot into Safe Mode.
  3. Open Driver Sweeper.
  4. Select "NVIDIA Display"
  5. Click "Clean".
  6. Close Driver Sweeper.
  7. Shut down.
  8. Connect 2nd monitor.
  9. Boot up normally.
  10. Install driver.
If not, then I recommend doing it this way just to see if it makes any difference. But of course, you may need to unplug the 2nd monitor in order to be able to complete step 8.
1 - 8 of 8 Posts
