1 - 16 of 16 Posts
is it using more HDD will cause OC's fail?? i am using 3 HDD<br>
because my pc was hang when i oc my x2 4400+ to 2.6Ghz(235*11) 1.6v<br>
why?? n also move my movie file to pen drivers also will cause hang.<br><br>
spec as below<br><br>
x2 4400+ 89w<br>
abit an8 ultra<br>
OCZ ddr500<br>
tt tr2 550w<br>
80gb + 80gb + 120gb<br><br>
Thanks
When does it hang? Boot? Or only big file transfer? Maybe try lower OC and see if it is problem.
such as big file transfer also at just watching movie<br>
more HDD will cause it fail??<br>
why i saw sombody with stock voltage can get high OC but i cant??
I have 4 HDDs... 2 are in RAID0... I don't get any hanging. If it is large file transfers, make sure the files or destinations (esp if flash drive) are not corrupted.<br><br>
EDIT: Might be ram, run MemTest86...
Discussion Starter #5
where can get it?<br>
RAM can cause PC hang when watching movie???????!!!!!
hi!<br><br>
What is your effective RAM speed, divider and VDIMM?
Oh yah...<br><br><a href="http://www.memtest86.com/" target="_blank">Link</a><br><br>
Download, burn image to CD, boot from CD and let it crunch for a while.
have you checked your temperatures ? Check that with <a href="http://www.almico.com/speedfan431.exe" target="_blank">Speedfan</a><br>
And here's <a href="http://www.memtest86.com/memt32.zip" target="_blank">memTest86</a><br>
stevemc you beat me to it !
Discussion Starter #9
<div>Originally Posted by <strong>Syrillian</strong></div>
<div style="font-style:italic;">hi!<br><br>
What is your effective RAM speed, divider and VDIMM?</div>
</td>
</tr></table></div>
220/11/2.8v
Discussion Starter #10
why i saw sombody with stock voltage can get high OC but i cant??<br>
sooo sadddd
<div>Originally Posted by <strong>gravity</strong></div>
<div style="font-style:italic;">...stevemc you beat me to it !</div>
</td>
</tr></table></div>
w00t!
dual cores use alot more power than single core cpu's and some single core cpus will use less voltage than others just luck of the draw
Administrator
Drop that V-core. You shouldnt have a mild overclock like that with that Much V-core. Just see if you can get it stable. <br />
<br />
No having More HDDS'S wont make your system more suseptible unless they are SATA drives which sometimes dont agee with overclocks as there operating frequency gets changed causing instability.
<tr>
<div>
Originally Posted by <strong>kuvga</strong>
</div>
<div style="font-style:italic">220/11/2.8v</div>
</td>
</tr>
</table>
</div>With 1:1 wouldn't your RAM be at 235 ("x2 4400+ to 2.6Ghz(235*11) 1.6v")? Not trying to be picky or irritating, just want to get all the facts down. Either way the settings seem okay. Time to try what stevemc and gravity said: run Memtest. Then post back <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<div>Originally Posted by <strong>kuvga</strong></div>
<div style="font-style:italic;">why i saw sombody with stock voltage can get high OC but i cant??<br>
sooo sadddd</div>
</td>
</tr></table></div>
Sometimes it just depends on luck
Maybe lower the v core and overvolt.That's the way I have mine @ 2.7,1.325 in Bios and overvolt enable.
1 - 16 of 16 Posts
