1 - 5 of 5 Posts
Right, earlier I ended a process by mistake in Task Manager, and my taskbar has changed to the classic Windows skin. New windows I open aren't affected by this though. I've been into display options and it's saying that the skin is already set to the one I want (Media Center Edition one). I know this is a noobish question, but I can't be bothered to waste my time in all the settings.
-Jake
You could try going to system properties(right click my computer and go to properties) then under system properties click on settings under performance. Then click the bubble that says adjust for best appearance. You could also put it to best performance but it'll be the windows classic theme for it all.
Hope this helps
Discussion Starter #4
Yeah, sure...
I had to edit it, I have 2 monitors and an LCD TV attached to this laptop...
Discussion Starter #5
Works! Thanks guys.
1 - 5 of 5 Posts
