1 - 6 of 6 Posts
i got my new zalman heatsink today, and i thought id be good and put it in before my work started, but once i put in the heatsink and turned it back on, the heatsink fan wont spin, and the video doesnt work. i cant get my comp running at all, and abit tech is closed. please i really need help
unplug everything and reseat also ck the power switch?
did u reset the cmos?
Discussion Starter #4
taking everything out worked, idk why, but thanks, you probobly just saved my gpa like a point or so
What is this heatsink for? CPU or VGA? Definately reset cmos. Also reseat the heatsink and see if that helps.
Discussion Starter #6
it was for my cpu, i had the stock intel one on there, and i idles at like 45. now i idle at 16
1 - 6 of 6 Posts
