1 - 8 of 8 Posts
Hi all.
I will soon get a ASRock B75M-ITX.
Please suggest a compact CPU cooler that won't interfere with the video card, RAM, cables, etc. - easy to work around.
Something about the same size (fan) as the stock cooler, but taller and cools noticeably better. (The NH-C12P just won't fit)
Room is 30c, i7-3770, SG08, GTX 680, RAM without heat spreaders, No overclocking.
thanks!
btw, this post is related, but no cooler can be found;
http://www.overclock.net/t/1357382/cpu-cooler-for-asrock-b75m-itx
Originally Posted by LuckySe7ens View Post
what case? no height restrictions?
aio h20?
The case is a Silverstone SG08, like I said.
So I don't see any height problems - even the NH-C12P is not too tall with the fan removed (for the case). But the cooler can't be wide ort it will hit the video card and maybe the RAM. And again, no overclocking, just something better than stock.
No water cooling please..
Discussion Starter · #6 ·
Discussion Starter · #8 ·
Originally Posted by Mitch311 View Post
Prolimatech Samuel 17 http://www.prolimatech.com/en/products/detail.asp?id=157
I'm using it on a Gigabyte mITX board and have no clearance issues with graphics card or RAM.
It looks like the Gigabyte has about the same layout as every other mITX board except for the Asus Z77-I. So the ASRock b75m ITX should also fit the Samuel 17.
That cooler is also very low profile and should fit in a CM Elite 120 as well as the Silverstone SG08
1 - 8 of 8 Posts
