1 - 20 of 23 Posts
Hi,
you can see my systems specs below ...please suggest me a good nvidia graphics card ..my psu is FSP saga II 350w ..lcd resolution is 1366 x 768
specs of psu
Product Features
Compliant for Intel Core 2 & AMD Athlon 64 series
ATX 12V V2.3 Ready
High Efficiency> 80%
Supports PCI-Express Connector
Energy Saving Standby Power Mode < 1W
120mm Variable Speed Fan with Ultra Low Noise
Eco-Friendly PSU with Active PFC
Thermal Coated Protection of White Casing
230V Input with Complete Protection (OVP; OCP; SCP)
Specifications
Efficiency80%
Input Voltage200 - 240 VAC
Frequency50Hz - 60Hz
PFC Active
Power Provided350W
Over-Current ProtectionV
Over-Voltage ProtectionV
Short-Circuit ProtectionV
Line TypeMain connector20+4PIN
4Pin+12V Power Connector4PIN
4Pin Floppy Connector1
S-ATA Connector3
4Pin Connector3
PCI-Express Connector6PIN
Case ColorWHITE
Chassis Fan120mm
Noise<21 dBA
Form FactorATX 12V V2.3
Safety ApprovalCE, CB, Nemko, TUV
Dimensions(LxWxH)mm140*150*86
please give me your advices ....Thanks
switch to ATI. They typically use much less power than a comparable Nvidia card.
With your psu, i would suggest the ATI 5770. Sells for $100 almost everywhere now and runs most games on high settings, considering your monitor is only 1366x768.
Originally Posted by neojjjk;11997638
I don't like ATI..
but hey how is gt 430 ? is it a good one?
I'd get a GTS450 ... the 430 is pretty low-end. Your PSU should be okay with a GTS450.
Waiting on New Hardware
definitely GTS 450.
although at this price point and power level i would recommend HD 5770, but you indicated you don't like AMD. (i haven't experience AMD ever before so i can't really defend them)
enjoy.
Discussion Starter · #11 ·
gts 450 is asking Minimum of a 400 Watt power supply... (Minimum recommended power supply with +12 Volt current rating of 22 Amps.)
GTS 450
or GF106 since you said GPU
I can't really find anything on that power supply, but the best card you could run on a good 350W power supply would be a HD6850. They consume ~20 watts more than a HD5770, around the same as a GTS450, but it will perform along side of a GTX460.
The best nVidia card you're probably going to be able to get away with is a GTS450.
1 - 20 of 23 Posts
