Soo, i was going over my invoice i received from Newegg, and noticed that something was off. The power supply in my invoice wasn't the one i remembered ordering.
Initially, i thought i had ordered the HEC Xpower 780 Watt, which really is a garbage power supply, but i figured it would do until i got something better. This thing isn't even the advertised 780 watt, rather it's only ~600 watt with badly fluctuating currents, i was aware of this but really didn't have the money to put into another PSU at the time.
However, in my invoice i notice that it says i purchased a Kingwin Mach 1 700 Watt power supply, which from first glance seems to be a much better power supply. Now, this quite pleased me because i was really worrying whether or not the previous power supply would struggle, and it was going to be the first thing on my list of upgrades (note my sig, i had planned on getting a 1kw Antec PSU). I'm not sure if i actually ordered this power supply and not the other one at last minute or something and just forgot (i probably moved some things around to make room for the money, but just forgot about it
), but personally i find this to be a great sigh of relief... at first glance.
Now my question for you folks is, whether this is a decent power supply or not? With this one, should i worry much about it not being able to effectively power my PC? Should i still go ahead and replace it as soon as possible with a better brand (i've never actually heard of Kingwin before i started putting this rig together, though Newegg seems to like it...). Or should this power supply do the trick. Should it be a solid enough power supply for my build, and possibly even future builds, solid enough that i don't have to worry about it killing my components?
TL;DR - Is the Kingwin Mach 1 700 Watt Power Supply a good enough power supply that i don't have to worry about replacing it with something better, and can focus my funds elsewhere?
Edit: Wow, 6 12V rails O_O.
Also know, i know very little about Power Supplies xD.
