1 - 6 of 6 Posts
hello there every body i'm new to the site this is my first question i hope you won't let me down i have an ati radeon 9800 pro 256 & i want to oc it how can i do that the hardware info as the catalyst control center says
Memory Size256 MB
Core Clock in MHz378 MHz
Memory Clock in MHz 351 MHz
so any one gonna help me doing this??
also i'm using the catalyst software any info if there is a better software .....thank you so much & i'm waiting your replay
Some cards do not have temp sensors.
When overclocking, raise the clocks 1 at a time 5-10 mhz and save it. Then in ATI tool use the "scan for artifacts" tool and run it for 5-10 min. If no artifacts then raise the speeds a little more. Artifacts are glitches in the picture you can see.
just run the aotu oc with ati tool that will find the max for ur card that is stable thats for both the gpu and mem
1 - 6 of 6 Posts
