1 - 4 of 4 Posts
i assume it is ATX...
those posts probally have like 2 solts cut in the top and look like they have 4 fingers ..they will be some of the standoffs just a clip in deal..........
get yoursely some studs that accept screws....for the outside edges at least............
just use 1 or 2 off the original one's to help hold yr mobo in place
Reactions: r_jhorton
The prefitted metal things, if they are brass in color, and have a place to screw into, are the standoff's you would need.
1 - 4 of 4 Posts
