1 - 19 of 19 Posts
So i unlocked my pny 465 w/ the black pcb from newegg. i used the asus bios, but now i can't OC it much because my computer will crash, even though the gpu core temp is only at 82 C right before it crashes. is it the card? is it the psu? is it my personality? what is it? lol. but umm here's what i tried:
800/1600/1802x2 @ 1.087 v = system crash/reboot
is my clock too ambitious? lol, but i have good ventilation in my system. my fan setting is good too (anything higher than 70 C i crank it up to 100%)
New OCN got me like...
Sorry I'm misunderstanding this, but does it:
1. crash with ANY OC period?
2. OC, then crash around 80 C?
yea, it crashes during furmark stability test with the setting i have above. i keep my eyes on the temp monitor and right before my computer dies the gpu core is around 81-82 C. i've read around and supposedly fermis can go into the 90's right? hmmm...
Please explain.. when does it crash? what are you doing before it crashes.. what have you done to it before it crashes.. ETC ETC!
Originally Posted by Schoat333
You need a better PSU. Mine would crash at anything above 1.05v when I had my BFG 550W. You really need a 650 or higher to OC the 470.
This is most likely the problem. Nvidia recommends a "Minimum 550W or greater system power supply" for the 470, and 500W won't cut it, especially for an overclock like that. Don't worry about the card, you just need a better psu.
It could conceivably be the PSU but personally I consider this outcome to be somewhat unlikely.
Try dropping to 775c/1750m. Not all 470's can do 800 at 1.087, and unlocked 465's tend to not be the greatest OC'ers unfortunately (but they are still an awesome deal!).
Could also try a voltage-unlocked bios and pump it up even higher if you like.
Your trying pretty high for your video card, most unlocks are probably only stable at higher voltages though YMMV, I know to get mine stable at stock settings, I had to up the voltages some, I found the memory to be a huge problem, won't go over 1770 w/o artifacts
Discussion Starter · #13 ·
i do have the gf 100 pny card... hmmm, possibly the psu. does anyone know of a good 650+ psu for about 40 bucks? i tried bechmarking the card at 775c/1717m and it crashed harder than a cat getting run over by a tank.
Discussion Starter · #14 ·
okay, so here's what i have in my system... no optical, 1 intel 40 gb ssd, 4 120mm fans, 1 200 mm fan, e5300 oc @ 3.25 ghz, asus xonar ds sound card, a tv tuner, wireless pci card, and the video card. my 500w psu can't handle all that?
Originally Posted by rick19011 View Post
You won't get a 'good' PSU for 40 bucks, maybe at least 80bucks you could get a decent 1 but 40 is far to low.
That!
650W PSU for $40,lmao!
You could sell your current PSU & add $40 to it & get something better.
Discussion Starter · #17 ·
hmmm... all good, all good, things will work out somehow. i just got an antec 750 earthwatt psu on newegg for about 80 bucks. here's to spending money i barely have...
Discussion Starter · #18 ·
and who would want to buy a 500watt rosewill psu? paying for the shipping alone is not worth it. i once sold a psu 450 on ebay for like two bucks, lol, and it was a brand new antec. oy... the headache...
Discussion Starter · #19 ·
so i replaced my psu with a 750w antec earthwatt and reflashed my bios with an overvolt one and i managed to run a full 3dvantage test without crashing @ 800/1600/700 @ 1.100mV, i down clocked my ram because i was suspecting that my core might not be the problem with heat, but it might be the ram... and i looked around, and apparently some unlocked PNY cards might have issues with its ram running at stock speed. right now im just pretty happy i got my card at 800 core without crashing.
1 - 19 of 19 Posts
