1 - 8 of 8 Posts
Could someone help me with gettin the most out of my gfx card. i'm using rivatuner. Or does the oc propeties in display (nvdia) do better. I do have an extra cooling fan point at the card. Avg temp at idle is 38-40. Also my old fx5600 at a ambenit temp sensor why does this card not have one?
Its a pny 6600 256mb agp
comp specs below
RivaTuner should work just fine for you. Increase your core by 10 mhz increments until you start to get artifacts or crashing in-game, when you start to see artifacts lower it by 5 mhz increments until they disapear. Then do the same for your memory speed.
I have an ASUS 6600 in another rig and it could reach 500mhz core and 700mhz memory.
1 - 8 of 8 Posts
