1 - 1 of 1 Posts
Hi All,
As the subject states I am wondering about overclocking my 780. First off it is water cooled so temperatures have never been an issue. I run at 1.2V with +220 Core/ +200 Memory (~1260Mhz). My temperatures never get above 60C so, I was wondering where to squeeze more out of this card? Is memory OC even important with the 312bit bus now? I noticed if I try to raise the memory OC any higher benchmarks tend to fail. Would it be better to just not OC the memory so I could go higher on the GPU core? Also would anyone advise a modded bios for everyday use or is it too much work for the performance gain? Thanks!
1 - 1 of 1 Posts
