5381 - 5391 of 5391 Posts
Have not actually touched MXM cards, not sure how those would work. Theoretically, they should have similar tables.
No idea how it operates for mobile, where each laptop can have different amount of outputs, beside monitor. I dont even know what the monitor actually uses as an output.
The risk of getting a no output to your laptop monitor (and others as well), is significant. Dont know where the VBIOS is located as well...
According my experience MXM cards have displayport (or other output type) lines goes from chip to MXM slot. Standard MXM card should have 4 displayport output's pins . Attached pinout picture.
Pinout:
Card photos:
On my motherboard only 3 of them goes to physiacal video slots. Also attached vbios files that allow to work one output. Different per each vbios.
pioneer krp500a
my creation
https://www.techpowerup.com/vgabios/222142/222142
MSI RX 480 GAMING X8GB bios david az mod
1380 Mhz 1250mv
memoey
Zero Fan =Off
2170Mhz 1150mv
250 MHz: 2-3-3-3-11-8-27
400 MHz: 3-3-5-5-17-9-43
600 MHz: 5-5-8-8-26-11-65
900 MHz: 7-7-13-13-39-15-98
1000 MHz: 8-8-14-14-43-16-109
1125 MHz: 9-9-16-16-49-17-123
1250 MHz: 10-10-18-18-55-18-137
1375 MHz: 12-12-20-20-61-19-151
1500 MHz: 13-13-22-22-65-21-164
1625 MHz: 14-14-24-24-71-22-178
1750 MHz: 15-15-26-26-73-22-192
2000 MHz: 15-15-26-26-73-22-192
It took me a whole day to build this bios
With the help of HEX editor
Have fun
pioneer krp500a
MSI RX 480 GAMING X8GB - bios david az mod ver 1
https://www.techpowerup.com/vgabios/222187/222187
As they say in Hebrew my card in terms of GPU lottery
קצת מעאפן
Some more improvements I made in BIOS
To get close to 1400 MHz.
I brought it up V limit 1275mv
I left in core voltage 1250mv 1E848
0C 01 03 06 = 48 E8 01
Setting an offset limit
1275 * 4 = 5100 = 13EC
( Without it the card will be limited to 1175mv )
8A 00 F1 FF FF FF EC = EC 13
Spec
card model MSI RX 480 GAMING X 8 GB
my mod bios is based on the original msi v bios 154
GPU CORE
1388 Mhz 1265mv
Zero Fan =Off
LLC = on
2170Mhz 1150mv
Okay, I'm looking for tips and tricks to mod an Asus Strix rx570 4GB OC.
What mods are available, what mods are recommended/suggested, what mods should I avoid and what mods are just nice extras for advanced tweaking?
I'm still using my 6 year old rig, specs are as follows:
Asrock Z97 extreme 4
4790k/coolermaster hyper 212 evo
32GB Gskill Ripjaws 1600(1866) CAS 9
1 x Asus Strix rx570 4GB OC
EVGA 750w Supernova bronze
27 inch Samsung curve monitor(non gaming)
How well does a rx570->rx580 conversion work out? Is it recommended or is it just a nice extra? If there are real gains/improvements, I'll try it out.
So, what is worth my time and what isn't? Any suggestions for other mods or optimum settings/timings as far as CPU, RAM or GPU that might have some useful effect?
Sent from my SM-S767VL using Tapatalk
top video tutorial
Go to my thread (sig) and download one of the BIOS files you find in post#2 (not the 570 files..). Compare it to an unmodded file from the exact same card, and only compare the Power Play table.
There are a few subtables in the PowerPlay to edit, the table length and image length of the BIOS; pointer for the beginning of the following subtables (header); at last the MemClkDepRecord entry for the additional mem state.
To be honest, i don't think you will gain anything. Memclock going down is also a driver thing, and don't expect the actual GDDR to be volted any lower or something. You barely see the 1000MHz State now, and if the driver doesn't know what to do with the many-states you want to add..
Still worth a try, though :thumb:
https://youtu.be/H8BwERRK3jk
hello guys
i had a problem onmy video card rx580 8gb plus after i boise this card
then is bricked
when i try fix get this massage ERROR 0FL01 : press '1' to continue"
so i need wich pins i must shot it
