1 - 19 of 19 Posts
Hi,
My setup is a Sapphire Radeon HD 7870 with a AMD FX-4170 CPU. On GTA IV I'm only getting 30fps (20fps with ENB) on high. Shouldn't I be getting 50-60fps with this setup?
Also: 8GB DDR3 on Windows 7 x64
Thanks
Last time I tried to play that game it ran like crap. I think you'll be fine with that gpu, but if you don't have that cpu oc'd, you might want to do that first then try the game. I could never get it to run very well either, always stuttered.
GTA IV is just very poorly optimized, sadly. I think I'm one of the lucky few who can get the game to run "Great", as in, there's occasional drops to 30-40 but it stays smooth (and by smooth and "most of the time" i mean 60+ 80% of the time
) most of the time. Too bad the Cutscenes are a mess on the PC version
start by trying an overclock then see what happens its not going to hurt anything. and about that nvidia thing did u used to have an nvidia card installed before? if so maybe you didnt remove the driver
that's definitely a CPU bottleneck, back in the days when i upgraded my Phenom II 1055T to a 2600K, i got like a 20FPS increase.
start with the cpu and if nothing gets better then try the gpu but its probably the cpu. dont be concerned with the vram for now if its only using 800mb then thats all it needs i dont think u have a problem there. and the other thing is probably just the benching software it is it a free version or paid? and maybe try uninstalling & reinstalling or updating it if possible
did you update the game? if not do it.
also browse the web for your problem.. theres an easy fix for your memproblem.
theres a way to start gta4 with no wrong memrestrictions ..
GL!
Your best bet is to upgrade your CPU. although overclocking can help a little, it wont be very significant (1-5fps increase) unless you can hit something crazy like 7GHZ
1 - 19 of 19 Posts
