Poor RAID0 performance on 780i
473 6
Hi,
I have installed three Seagate 7200.12 500GB hard drives on my sister's computer and configured them in RAID0. The problem is that I can see no performance gain compared to when there were two hard drives installed in RAID0 in benchmark software like HD Tune or HD Tach.
The motherboard is EVGA 780i with 64K stripe size.
Any suggestion what the problem might be?
1 - 7 of 7 Posts
Originally Posted by joemaniaci View Post
its fake raid, has to use the cpu for most the work so its not very effective.
7.7% CPU Usage. That's not the problem. What usually is the problem is that those things have a maximum bandwidth. Notice how it is level to 175mb/s up until the very end? When it is not controller limited the bandwidth will be arching downwards.
tl;dl
Integrated controllers. Limited to 175mb/s.
tl;dl
So is there a way to increase this bandwidth?
tl;dl
not all integrated controllers, but definitely the 780i.
yeh, nvidia, got the greatest, but intel is top notch. Of course the very best is an add-in card, but very expensive.
I'm not going to buy an add-in raid controller. & I think I will use two hard drives in RAID and the third would be for normal archive. Or I might just go with RAID5.
1 - 7 of 7 Posts
