Originally Posted by
victorzamora
You can try reseating your waterblock to make the temp on Core2 drop. However, I doubt it'll help. This sounds like the classic Ivy Bridge crappy TIM that Intel has made Ivy Bridge so famous for. Have you read about this? If not, here's a quick run down:
Ivy Bridge chips use TIM between the core itself and the heatspreader. Nearly all other chips have been soldered directly to the heatspreader. Intel did a crappy job applying TIM properly between the core and the heatspreader. The only two ways of fixing it are to lower your OC (deal with it) or delidding it. Basically, delidding is when you pull the heatspreader off, apply your own TIM, and then reattach the heatspreader. It's dangerous, but by all accounts it's been well more than worth the effort if you need the power.
