1 - 3 of 3 Posts
I have a linksys BEFSR81 router.
My problem is, when I try and use DMZ or just open all the ports on my computer (I did "ipconfig /all" and i am running on 192.168.1.101) nothing happens. I do a port scan, and they all still appear to be blocked, or closed. I do not have windows firewall on (I set it to off).
Any ideas?
I wouldnt use dmz unless you really need it
log in to the router, click "Applications & Gaming" and you should be on the "Port Range Forward" page... has that not worked?
1 - 3 of 3 Posts
