So a couple of nights ago I was pretty drunk and sleeping when I awoke to a loud noise, which I ignored. Then the next morning I woke up and realized that a glass of water had fallen over and onto the floor. I didn't think much of it until now, but I think you can guess where this is going.
My U9BLS suddenly stopped working properly. The space bar, escape, g, h, ', and up arrow keys no longer work. I unplugged the board and took it apart. This is where it gets weird, I tried shorting the solder points for some keys, and the keys that I mentioned still didn't respond. The other keys I tried did respond to this.
So the problem isn't with the switches themselves, but with something else. (unless my logic is flawed, shorting the solder points should bypass a faulty switch)
I'm at university so I can't really desolder the switches (which I don't think would matter based on the line above)
Relevant info:
1. it was water that spilled, and I don't know how much actually got on the board
2. there was about 48 hours between the time it spilled and the time it stopped working
3. the affected keys are not located near eachother on the board except for the g and h keys
4. I tried the board on a different computer and the same symptoms exist
5. same thing happens when plugged in with USB and PS2
6. all the LED's still work fine
I searched through the Wiki on here to no avail. The section about fixing keys seems to focus on the switches being faulty or corroded, which they don't seem to be (because of the issue with shorting the solder points)
Well, that is about as much as I can say for now. If anyone has any ideas I'd love to hear them
Thanks <3
Relevant info:
Thanks <3
