Hi there,
After installing my first custom water loop, I was reminded of how annoying it is to have a non modular power supply. My TX750 has a lot of cables that are thick, stiff and hard to manage cleanly.
Therefore, I am looking for a modular design with single braided cables. I've been very happy with the unit from Corsair in the past and would have no issues going with them again. It's also handy that they sell modular sleeved cable packs. You might ask why I don't just sleeve my own though, but I don't think I'd be able to do as good of a job as I would like. However, I may give it a try at some point in the future. I'm using sleeved extensions at the moment but I would prefer not to as they just add even more length that has to be managed.
I have quite a few components in my rig and would like a nice amount of power to leave headroom for overclocking and component upgrades in the future so I feel as if the 750 range would be ideal for me. An efficient unit is also a plus!
So here's where I am asking for your help. What unit would you suggest based on my points above? I have been looking at the following unit from Corsair -
http://www.scan.co.uk/products/760w-corsair-ax760-full-modular-80-plus-platinum-92-eff-eps-12v-sli-crossfire-1-x-120mm-fan-atx-psu
With these cables. It doesn't say they support the 760 in the description but it does mention all of the other AX units so I assume this won't be an issue. Anyone that knows different, please feel free to correct me.
http://www.scan.co.uk/products/corsair-individually-sleeved-modular-cable-upgrade-kit-for-the-pro-series-ax850-ax750-ax650-psus-bla
Tell me what you think! Sorry for the long post!
