1 - 20 of 1020 Posts
Ok, here we go. I used to have this all installed in an Antec full tower, with 7 case fans, but I have been doing a lot of work on it lately, so I decided to 86 the case for a while. Plus I am moving in a few months, so I am just gonna leave it alone for now. And it's super easy to work on like it is now. Also, I don't have shrouds on my heatercore because I am building some new ones. My temps only increased 2 degrees without the shrouds. BTW, that little grey box is a seperate psu for my fans. The two fans on the front of the heatercore are 130cfm 12V Sunons.
Notice the little pieces of tubing holding up my fans and seperating the sound card from the pci fan card?? LOL, truly ghetto!
Reactions: ThE_GeNeRaL
You should be warned that this isnt for faint hearted.
This is the ugliest looking thing that youll ever see.
I modified a toolbox and put the watercooling parts in there (bar the waterblock).
It runs from here then into the case haha
Swiftech MCW6002 on a Athlon 2500+ OC'd @ 2.2Ghz std volts
Distilled water and 5% Water Wetter
Fan is EverCool PCAC 53~100CFM lateral turbine fan (quiet at 100CFM!)
'77 Bonneville heater core
Dolphin DP-385 pump
This hole in the side of the case previously an air duct to the cpu...
With Air Cooling: 52C idle / 63C prime95
With H2OCool: 42C idle / 46C prime95
Got a good 17C drop!
This is my .9beta setup. The final one will be out of hardwood and have a quieter pump and be of more exacting finish....
