261 - 280 of 717 Posts
OG AMD
3152 Ryzen 5 2600 @4.1 3266MHz Ram on single tower air
Reactions: MrFox
Overclocked / Overvolted
Reactions: MrFox
Invalid Media
'Grats to both of you...and good advertising for the Hailea 500 chiller, also. Then again, AVX/512 etc without that kind of cooling at those settings would make me a tad nervous :sad-smile
Old and Decrepit
Reactions: MrFox
i9-9940x Cinebench R20 score 7471 cb
I'm happy with my Cinebench R20 score.
Asus Prime Deluxe II
TridentZ 3200
ax1600i
Noctua D15s
Fractal R6
MCE: On
Additional Overclock: No
Multiplier: 41
I think this score is pretty crazy considering I'm only running 4100Mhz no?
Idle temps at 35c, I hit 80c on the package while running the R20 bench.
Let me know if you think I should change anything for lower temps. I don't need more performance than this!
Overclocker in training
Hi,
@ianross
You're not showing enough to really say much more than changing your cpu cooler :)
@JustinThyme
That's sweet man I post 8810 earlier at 4.8 might try for 4.9 eventually :thumb:
Reactions: usmc362
Old and Decrepit
Reactions: MrFox
Just when you think you are getting somewhere MrFox comes along.....
Nice scores as always!!
I may invest in a bench system with a chiller again one day and give you a good run!
Thanks for the compliment. That would be great. Would be awesome to see more folks jumping on the chiller bandwagon. I really love mine. High temps are the root of all evil in PC world, LOL.
9900K @ 5.3GHz, Cache 4.8GHz, 2x8GB Trident Z 4133MHz 17-17-17
5623 pts:
Reactions: MrFox
14973 2990WX, 4.15GHz, 3400MHz ram, simple MO-RA3 420. Chiller is here waiting on a pump upgrade. Sub-ambient coming soon
Old and Decrepit
Its a different type of challenge. Last one I ran was made from a 22000BTU widow AC. Fine balancing act keeping things as cold as you like without having to worry about condensation. Once my old age really sets in.....aka youngest out of college....and I can give up the daily grind Ill need something to keep me from going bat sh_t. Last weird cooling system I did involved geo thermal. Old radiant floor heating coils buried under the concrete in my basement, dirt is always right about 62F no fans anywhere. pump was 1/4 horse in the basement with low voltage lines running down to pull in the pump relay with a 12V coil. Completely silent and actually far more efficient than using ambient air over radiators. I never managed to saturate that loop. Resevoir was a 5 gal bucket in the basement.
Hi,
Yeah I'll probably end up with a a/c server cooler nice and easy and I can use it for other projects like if the a/c goes out and outdoor outings.... ;)
Water chillers are only good for one thing.
Old and Decrepit
Hi,
My AC chiller was an AC gutted with the evaporator submerged in a glycol solution so very much still only one use. Lots of folks took the poor mans chiller route before me. Not overly difficult to do and you can get a much better capacity with it. 22000 BTU is good for about 6000 watts.
Hi,
I'm not greedy
I'd be happy with 15c air on demand year round :D
Just hangin' out
With new parts.
5230 cb - 9900k @ 5GHz
