**Post Your Linux Setup**
2629 41
A few people on here use linux so i thought - why not?
Post a screeny of your desktop (tidy or otherwise) what distro and window manager your using and the systems specs - if it isnt in your sig. Throw in what ever else you care to tell us about ur tuxbox.
Im installing Ubuntu with KDE as i type. Ill post mine in a couple mins.
1 - 20 of 42 Posts
I don't have a screenie, I need to reinstall it lol. But I'm running mandriva '06 with the GNOME desktop environment...might change again to kde, but I don't know. and the rig its on, well its in my sig.
I uninstalled when I got my new rig, but...
Was running Ubuntu on a 454mhz Pentium III coppermine, and a beastly 256MB SD RAM, with a nVidia Riva TNT 2 M64 card =)
Does anyone here run gentoo? i found it impossible to install
Discussion Starter · #11 ·
Mandriva Time! Kunbuntu got on my nerves, so im installing Mandriva 10.1
As noted earlier, it's really not that hard to install.
A screenie from way back when I had gentoo + e17 and cedega too. I want to install gentoo again, it's just time-consuming. That's all. However, let it be known that if I have gotten anything of out linux, it's learning how it all works, with Gentoo. FreeBSD might be worth a dabble methinks. Time to learn why I didn't like it.
Fedora, don't even remember when I had that. As you can see, doom3 was installed.
To be edited: Was playing css (first time in months lol), brb with a ubuntu/gnome screenshot.
Originally Posted by jbrown
WOW thats a high RES lol...
I believe he is on two monitors (1280x1024 + 1280x1024)...not too high. But yes it's hard to fit on our screens
Discussion Starter · #15 ·
Woo..FC5 rocks! i got mp3 support working. Next task is to get it to mount my data partition - although I may just convert it to FAT32 and save the hassle.
Take a gander.
FC5 with Gnome and Darker Theme from Gnomelook.org
Standard Icon Set
Custom Desktop-ish
Take a gander.
Standard Icon Set
Custom Desktop-ish
you just have to download the ntfs rpm for your kernel and then edit your fstab and mount it in terminal.
with ntfs you can read but not write though anyway which is a pain in the arse so I always have a FAT32 partition to shared files between
Discussion Starter · #18 ·
I'm gunna convert the ol' NTFS Data partition to FAT32 - I may loose some efficiency but heh.
Jester,,where did you get the black theme, I don't have that one. Look cool though. I'll post a screenie of mine in a bit.
Discussion Starter · #20 ·
Hehe - I've been asked about my themes numerous times
I like the black themes for stuff. I'll have a hunt around for the link if you want.
1 - 20 of 42 Posts
