Wow![]()
If you want to know how many drives a 750D can fit the answer is 24...
stuffWow
What do you stock on theses?
Sent from my LG-M470 using Tapatalk
:lachen:stuff
Wow
Good stuff...Here is my new baby:
A Dell R720.
Specs are :
Dual Intel Xeon OCTA Core E5-2670 2.60Ghz (16 cores, 32 threads total)
64Gb RAM (DDR3 Registered ECC Dimms)
16 X Hot Swap Hard Drive Bays
Dell PERC H710 Raid Controller with BBWC (Support RAID0,RAID1,RAID10,RAID5,RAID50,RAID6, RAID 60)
4 X Gigabit Network Ports 10/100/1000
2 X Redundant Dual Power Supplies
4 x Crucial MX500 250GB SSD's in RAID 10 for OS + VHD's
4 x ST5000LM000 5TB HDDs IN RAID 6 for storage (shucked from Seagate Backup Plus 5TB Portable)
More details available in my thread : http://www.overclock.net/forum/18083-build-logs/1682193-build-log-32thread-64gb-ram-home-server.html
Cheers, definitely different with it's 4x all in one water cooling. Yep that's where I moved the bottom 140mm fan to in the end after fabing two metal plates. Helps a lot with temperature, as the ram gets cooked by the Jordan Creek II memory buffer heat sinks. I bought all my ram second hand off ebay and had several soft ECC errors. After replacing those bad DIMMS (3 out of 32, not a bad failure rate considering it was half the price of new, ram is such a rip these daysThat looks insane and beastly as heck! Really interesting build. You might be able to fit a 140mm fan where the 5.25" slots are (if true 140mm spacing holes) since the edge of the bays seem to have a few holes still (possibly use washer & nut). A 5.25" bay is 133.35mm, so those holes might just be in reach. Just throwing ideas out there. There are 5.25" adapters of course but since you don't have the bay side walls anymore to screw in, I don't think it would work. Not to say you really need it.
Awesome machine indeed...Cheers, definitely different with it's 4x all in one water cooling. Yep that's where I moved the bottom 140mm fan to in the end after fabing two metal plates. Helps a lot with temperature, as the ram gets cooked by the Jordan Creek II memory buffer heat sinks. I bought all my ram second hand off ebay and had several soft ECC errors. After replacing those bad DIMMS (3 out of 32, not a bad failure rate considering it was half the price of new, ram is such a rip these days) and the additional fans, it's running great now.
Your best bet it to search for EOL obscure modules from the big 3 manufactures such as: m393a2g40db0-cpb and mta36asf2g72pz-2g1a.Awesome machine indeed...
Not sure where this 1/2 price ram of which you speak lives on ebay? ;-)
I'm seeing lots of full-boat $200/16G for "pre-owned".... I'll keep looking.
He's my contribution:
CPU: 4 x E7-8894V4 ES 24 Core @ 2.3Ghz base, 2.7Ghz all, 3.2Ghz boost
RAM: 512GB DDR4 (16GB 2Rx4 DIMMs, mix of Micron and Samsung ebay specials as ram is stupid expensive these days)
MB: Supermicro X10QBL-4CT
NIC: X550T2 20Gbit Bonded
NVMe: 256GB Samsung PM961
Case: Rosewill Blackhawk Ultra (heavily modified to fit non standard mb, riveted drive cages removed, top fan grill altered to accommodate push/pull cooling through AIOs)
Coolers: 4 x 92mm Asetek 545LC AIOs, 17+ Noctua fans of various sizes.
OS: Debian 9
That chassis picture was part way through my build and is a little old now. I switched the bottom intake for a 200mm, moved the old bottom 140mm to the front top and attached 2 additional 92mm to the motherboard to cool ram. System pulls around 1kW at load, idles around 160w. Added some pretty time series graphs and htop screenshot of it running too /forum/images/smilies/smile.gif
