1 - 18 of 18 Posts
I would like to see something done with the V1000BPlus II, cuz its a case that i want but can't afford
So thats my vote
MaK
I like the PC-V1200B Plus II best, the first is good but im not keen on the PSU mounting place, the third is good also but some of the cooling ducts won't like big HSF's rendering them useless.
Originally Posted by Chopes
PC-A10B
Others look ugly.
I agree
Filthy Casual
Are you open to other suggestions by any chance?
If not, I'd have to say the 1000, I personally like the looks of it best, and the mobo tray mine lacks...
If you are open to other suggestions, I would recommend the Goliath: http://www.performance-pcs.com/catal...ducts_id=20854
Discussion Starter #11
Sure, fire away!
I just really like the all-aluminum construction of Lian-Li's cases- They are (pretty much) unrivaled in terms of build quality, attention to detail, etc. in a stock case.
Also, keep in mind I have 1) watercooling, and 2) 4 (soon to be 5) hard drives in a RAID config.
Ill check one sec
It looks to be 15/16 of an inch in diameter when I put my ruler straight across in the middle. Ill take a picture once I find my camera so you can see if I measured it right.
PC-V1200B Plus II FTW.
1 - 18 of 18 Posts
