1 - 4 of 4 Posts
Using the dremel bits on the power drill, would this even work?
if the chuck will hold something that small you will be fine.
It depends on the bit.Most dremel bits run better at high speeds.
Won't really work.
Most drills run below 2,000RPM, While Dremel tools, Run 15,000RPM - 30,000RPM + to run peices like the cutting tool, So I doubt it would work very well at all, MAYBE the drum sander, But not the Cutting tool.
1 - 4 of 4 Posts
