1 - 6 of 6 Posts
hey guys
my Bios happens to reset when i disconnect my PC, every time.
my MoBo is asus m2a74-am se with a athlon II x2 240.
it says "hit F1 for setup, hit F2 for default settings."
usually i hit f1 cause i'm overclocking my regor
got a suspicion that it is a jumper or something.
thanks
i took it out, and i got 3,17V but Everest sais 0,85V. jumper?
That's the motherboard 24 pin power connector, looks like your only using a 20 pin Power Supply, not sure if that's what is causing your issue, but you should look into weather you are getting enough power through the board.
Discussion Starter · #6 ·
i've read about it, and i doubt it has something with it to do.
1 - 6 of 6 Posts
