Originally Posted by Evil XP2400 Let ATI tool find your maxes... First your core, then your mem, dont do both at the same time. |
Originally Posted by Xavier1421 I may be overstepping here, but what he meant was: Find max core first...then reset it back to stock (after writing down what the max was) Then you find max memory. Each "find max" you do will take some time to complete fully. Once you find your two clocks, then you manually set them in ATI tool together, and check for artifacts. I've ATI Tool alot, and I dont remember it restarting my system...hmmm |
Originally Posted by fourstar77 Yeah, I did what you said, found max core, system restarted. Went back in at stock, found max mem, system restarted. Then set both at the indicated maxes (when you start ATITook back up, it tells you the last safe frequency), and tested for artificacts. Seems to be running fine overall. I have the system OC'ed from 1800 to 2300 (255 FSB w/ 4x HT mult), and have run prime95 for several hours with no crashes or errors. So I think in general everything is looking good. I did notice that my temps were jumping up to the mid to upper 40's when I was finding the max core and mem speeds, but from what I have heard that is fine (anything below 55 C for these AMD 64's is good). So unless you think that the restarting is really problematic I think I will leave the system as is for now. I bet I could get my FSB even higher as my cpu voltage is only at 1.5 (stock 1.4), but I just have not seen informaiton out there as for what the max should be for cpu voltage for AMD64/MSI Neo2 Plat combo.. Thanks for the note! |
