1 - 12 of 12 Posts
Originally Posted by spookedjunglist
definately the same screw arangement...
but shape and size may differ a little bit,
^^^^ yep, what he said.
Anyway to know precisely if a psu will fit, just from ordering on the internet?
and is thermaltake a good brand?
(trying to upgrade psu for a 6800 or x800)
if it's ATX it should fit. Thermal take is alright, not the best but not the worst. sometimes it says the dimensions right on the ad for the PSU, check it out and measure.
Originally Posted by ATVkid*AFZ*
if it's ATX certified, then it will fit all ATX cases.
Whats a really reliable/good brand, looking at a 420-450 for around $100 us
Known Good PSU's:
Antec, Astec, AOpen, Channel Well, Enermax, Enlight,Fortron Source (Sparkle), HEC, Hi-Power, Jeantech, NSpire, PC Power & Cooling, PowerMan, Seasonic, SilenX, Tagan, Thermaltake, TTGI/SuperFlower, Vantec, Verax, Zalman
Known Bad PSU's:
Achieve, Allied, Aspire, CoolMax, DEER, EYE-T, KingStar, L&C, Linkworld, PowerMagic, PowerUp, Powmax, Q-Tec, Raidmax, Skyhawk, Star, Turbolink
Power Supply Wattage Calculator
The link above will help you determine the correct size of PSU that you need.
AK
Holy crap i got a Linkworld, yeah i know it sux!!! really BADLY, but i want a thermaltake, i had good experience with one, my cousin gots it, its nice (tt butterfly!!) its very cool
IF you are looking for a nice psu around 100$ you might be interested in this even if you dont want/need the case but you about 110$ you get a 500w modular psu and a case
http://www.tigerdirect.com/applicati...241&CatId=1516
1 - 12 of 12 Posts
