So I am in the market for a new PSU, and I am having a bit of trouble deciding. I need my Power Supply to be black, I need it to be modular (preferably the cables to be as long as possible as well), and I need it to be 750w or over. Also, under $200 please!. If you have a PSU you would like to recommend, but its over $200 please recommend it anyways, and I will see if I can find it for cheap online, as NCIX does price matching.
For a long time I was thinking definitely I would go with the Corsair HX850w. Outstanding reviews, black, modular, 80+ Silver, did I mention outstanding reviews?
But recently, I came across the SeaSonic X750. Its a 750w psu with an 80+ Gold rating. It is black, it is modular, and best of all I can find it for $166, whereas the Corsair HX850w would set me back $179.
So, from the reviews I have read, the SeaSonic X750 is great, perhaps even top of its class. Here is one from Johnnyguru, but its on the 650w edition. I am quite confident they would be similar in performance. http://www.jonnyguru.com/modules.php...Story&reid=169
Here is one on the 750w http://www.hardocp.com/article/2009/...supply_review/
You might be thinking based on the reviews that there is no argument here, but I just want to be sure, and the best way to be sure is to ask the folk at OCN!
So, whats your opinion? SeaSonic X750, or Corsair HX850? Also, if there is another PSU you would like to recommend, I will gladly here your thoughts, but I would appreciate an explanation as to why your new suggestion is better than the two I already have in mind.
