1 - 20 of 22 Posts
i dont think you need to really i ran a gtx 260 and my 955 at 3.84ghz with my ocz 500 watt. But my parents need a new psu for there comp so i gave them mine and they bought me a new one. But if you think you may crossfire the 5770 then i would get it but if your not then you really dont have to.
Originally Posted by Tator Tot
You don't need an upgrade. But you should probably move to a better unit.
This Antec Neo ECO http://www.newegg.com/Product/Produc...82E16817371030 should do you well.
Very good psu this man posted. I would lean towards this myself.
Originally Posted by Jesherie
Yeah, I may crossfire in the future as well, but I doubt it since I game at 1280x1024, it would be overkill.
In that case I would reccomend atleast a 700-750 watt unit. for both overclocking and CF use.
Absolutely not.
a HD5770 only uses ~105watts at 1.4v 1Ghz core.
@ 4.2Ghz 1.55v you're looking at ~200watts for a Phenom II x4
That's only 404watts on the 12v rail. A good 500-550watt unit will do
Originally Posted by Tator Tot View Post
Absolutely not.
It's 118 Watts stock, but yeah, 500W psu if high quality should work great. I have had my cpu running at 1.55V with my gpu running at 1.175V and my psu is only 21A on the 12V rail
(It was free...)
Absolutely not.
This. The 5770 is very power efficient..no need for over a 600+watt PSU.
(It was free...)
118watts is the TDP. Not the actual power consumption. Two different things.
No you don't need to upgrade PSU
You can and there are alot of good suggestions in this post.
On my OCZ 600 watt (a few years old and not the best of the best psu) I ran:
E6400 @ 3.4 ghz
8 gigs ram
2 x DVDRAM
4 x HD sata 2
2 x 8800 gts 320 (at one time)
3.5 floppy
front memory card reader
tv tuner card
I know they are different, but I'm pretty sure 118 is the power consumption.
Either way, 15W won't make a difference
http://www.newegg.com/Product/Produc...82E16817171031
I forgot, I also have that PSU lying around in my spare parts, would that be a better build quality then the Rosewill would?
No, your Rosewill is a much better unit than that unit.
Cooler Master eXtreme Power series is a stack'o'turds
Discussion Starter · #18 ·
If I were to eventually get a 2nd 5770, what kind of PSU would I/should I look at? If I'm gonna buy a new PSU I want to future proof a little. Would a good 550W like Corsair be too little?
Yeah, any good 500-550watt PSU would be fine.
1 - 20 of 22 Posts
