1 - 4 of 4 Posts
I keep getting a random error pop up in the taskbar in windows 7
says something like "Power surge to the USB hub" blah blah, however I only have my keyboard and mouse plugged in, both of which still work.
I can't get it to happen on command, it seems to be totally random. Happened 3 times today, once this morning after closing down a game, and twice this afternoon while browsing.
Is this something I should be concerned about cause I have no idea what's causing it.
Leader of the #1 [email protected] Team
never heard of that before. But if everything works and only 2 things are plugged in then you should be fine.
Might be going out on a limb here but.....some sort of Virus/Spyware??? Just a thought...
I had a similar issue a long time ago and it turned out the front case USB ports were the issue. I managed to pinch the cable running to the motherboard header. It was to the point I could see bare wirethrough the cable sleave. I replaced the cable and fixed the problem. The only thing therefore I can suggest is, check your USB cables running to the motherboard headers.
1 - 4 of 4 Posts
