1 - 19 of 19 Posts
So I'm going to finally replace my 5870 with something new and now with never settle reloaded seems a good time.
I could not decide between msi or sapphire at first, but then I stumbled upon powercolor cards with the v3 cooler. Their cards look nice, seem to have a decend cooler, are fairly cheap and have 2 dvi + hdmi like sapphire flex, wich would be ideal for me, because I#m going to upgrade to 3 monitors as well. But I was not able to find lot's of data on thoes cards, so maybe someone here knows something about them. I'm looking for something that runs cool, quiet and oc's well.
(Decision between 7950 and 7970 will be made based on how much money have at the time of buying
Here are the powercolor cards, the page is in german but the important stuff should be undersatndable.
7970: http://geizhals.at/756084
7950: http://geizhals.at/830660
· What should be here ?
I would go with the HD 7950 but from Sapphire because they run really cool , overclock really well and are voltage unlocked. Here are the choice
http://geizhals.at/830654
· Premium Member
Yeah thats a very good card. Sapphire HD 7950 boost with dual x cooler. get it with the game bundle. 29 cm long . should fit easily in your ANTEC 1100.
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1157&pid=1713&psn=&lid=1&leg=0
http://www.mylemon.at/artikel,nr,426215,SAPPHIRE,HD7950_3072MB_DDR5_LRTL_384bit_PCI-E.htm
Thanks for the answers.
I finally managed to find some customer reviews on newweg, some saying that the vrm cooling is crappy, so it's difficult hitting over 1000 mhz core without it overheating, especially with the overclockingpotential of this card (I've read some prople hit 1300 core)
Well, sapphire would cost just a little more and also have2 dvi + hdmi. And I think they actually come with active dp to dvi adapters. Or a card from msi. I really like their design. Oh, I hate decisions
I'll wait, maybe someone has a game changeing argument, but if not I'll go with sapphire or msi
So I've done some more research and came across the sapphire vapor x card, wich, acording to this webiste and the manufacturer website seems to have a 7970 pcb with 8+6 pin power and what looks like 9 power phases instead of reference 7 I think, wich should theorethically make it a good overclocker. It also has 2 dvi + hdmi + dp port, but I could not find out if you still need the dp port for eyefinity. Maybe someone has an answer to this.
· Premium Member
yeah you need dp with the vapor-x. only the sapphire hd 7950 flex allows connecting 3 monitors without needing dp connector.
http://www.sapphiretech.com/Flex/FleX_Eng_apply.html
Looks like I'll need dp anyway because no retailer in my country, that participates in the never settle reloaded promo sells the flex edition.
So it seems like I'm stuck between sapphire vapor x, dual x or msi tf3 (I really like the design on that one) Question is if the aditional power phases on the vapor x actually adds any benefits and wich one cools better (maybe I should start a new thread just on this)
@ Hogwasher I don't think that powercolor is a bad company, just the lack of vrm coolers is annoying. If I could go watercooling I would go for it, but the parts are hard to get and expensive over here in austria (especially thoes 200mm rads for my antec 1100
And thanks for the help
Because the Vapor-X has more power phases, it would run cooler compared to the Dual-X.
Discussion Starter · #14 ·
Found some reviews with nice pictures for the Vapor X and dual X. It seems as if they use the same pcb, but the vapor x has a 8 pin instead of a 6 pin and has two more vrms mounted. As for vrm cooling, the vapor X looks bigger and the ram modules are cooled directly by the vapor chamber. It also overclocked better, but that is probaply just luck.
going to go against the grain here, and state that i have a powercolor 7950, and its great, volt unlocked, currently hits 1280 under water at 1.3v, 1370 at 1.381v, although i did run it stable 1250 on air, just didnt like temps, noise is aboslutely fine.
+1 this..
Its currently under water, but I have the old heatsink, ill find it for you later. The v2 definitely has heatsinks afaik the v3 doesn't...
Discussion Starter · #19 ·
Ok, thanks for the hassle
But I'll have to check with my retailer anyway, because the powercolor card is not listet to include the never settle bundle, if not I definately would go with something else. You don't get 120€ of free games every day
1 - 19 of 19 Posts
