1 - 16 of 16 Posts
ok giving away rep points to ALLL that help me....first i had an nvidia geforce4 mx 440....full unistall..used detenator rip 2....install radeon 9600 SE....installed drivers fine...tried omega driveres fine...uninstalled omega drivers....using ati drivers fine....returned radeon 9600 se.. using geforce4mx 400 installed nvidia drivers...uninstalled....detonator rip...installed powercolor radeon 9800 np or pro....fine WITHOUT drivers...installed 4.11 drivers...after reboot there are small graphical glitches....uninstalled and installed 4.12 same thing...installing it from cd right now but WHAT IS THE PROBLEM!? will post updat in 10 mins or less
There might be regkeys and things left from the other video cards that are conflicting with the drivers.
ATI's are picky when it comes to this. Always use ATI Driver cleaner/or whatever driver cleaner you perfer before installing new drivers, this will save you from alot of headaches.
all right im in safemode using registry programs to attempt to find and delete em...is there a way to get rid of the regkeys? any way besdies reformating...
pic 1http://***omatic.com/7/problema12.jpg
pic 2
http://***omatic.com/7/problemb123.jpg
pic 2
Search for ATI Driver Cleaner, that will get rid of all the other ATI driver stuff. ALL OF IT!!
NEW: http://***omatic.com/7/majorproblem23.jpg
after i did what the readme file said...safe mode...uninstall..unplug modem...reboot..installed ati drivers 4.11 normal from acutal website... getting that kind of glitch
please help thanks
please help thanks
I'm out of suggestions... Is your card correctly seated??? You might want to try physically resinstalling it.
Try installing different drivers, go from the reg ATI ones, DL the omega drivers, use the drive clean, install the omegas, try it then, idk.
Reactions: thehacker11
well shouldnt the orignal ati ones work? read my sig its the powercolor radeon 9800 np/p
They should, but there is always that one card that doesnt like an specific driver.....
yeh, just play around with different drivers, who knows, you might hit something.
make sure it isnt overclocked ....
When i oced my 9600 it glitched so bad i couldnt see
if It gets really bad then take a old pci (video) card from any old computer
this will let you see
now for the drivers you may want to try downloading a different driver
there is a site up in the ati section where I posted 9600 overclock or something like that
well anyway get the link the guy sent me and you can put in any model and
it will give you many drivers
I'm not sure if it helped at all but this is what I did .. O and I used flashrom
and the drivers.. look aroudnt the ati section
While your all talking about 9800's... I've got an ATI 9800PRO 128mb, I wanted to get some memory cooling chips, but then I realized that some Samsung chips only overclock to a certain point. Does anyone know how I could tell which revision they are? I looked on the mem chips themselves and theres no markings on there except for some serial numbers.
1 - 16 of 16 Posts
