A quick tip I forgot to mention.
There's a weird bug, at least in Win10 v2004, which prevents the scheduled tasks to run properly if attached to an event in a custom view.
So don't try to create the task from a custom view; I banged my head a while on it because I have a custom view for the WHEA errors.
The task will run and reported working fine but the program attached to it will not run...
Just use the standard Application, System, Security views in the Windows Logs section.
