I was just changing core states 5, 6, and 7... no voltage changes until I can get the most simple of change to work..
Are you getting the soft powerplay table mods to work on linux now? I can't see the start of the thread going back 6-7 pages other than the notes about patching the linux kernel. I would love to be able to apply this to a linux box.Originally Posted by dallase
pp_table# diff -Naur orig mod
--- orig 2017-10-05 14:08:14.966982754 -0500
+++ mod 2017-10-05 14:08:22.819099001 -0500
@@ -10,8 +10,8 @@
01 08 D0 4C 01 00 00 00 80 00 00 00 00 00 00 1C 83 01 00 01
00 00 00 00 00 00 00 00 88 BC 01 00 02 00 00 00 00 00 00 00
00 B4 EF 01 00 03 00 00 00 00 00 00 00 00 80 00 02 00 04 00
-00 00 00 00 00 00 00 C8 3F 02 00 05 00 00 00 00 01 00 00 00
-C8 58 02 00 06 00 00 00 00 01 00 00 00 18 6D 02 00 07 00 00
+00 00 00 00 00 00 00 A0 03 02 00 05 00 00 00 00 01 00 00 00
+94 05 02 00 06 00 00 00 00 01 00 00 00 88 07 02 00 07 00 00
00 00 01 00 00 00 00 04 60 EA 00 00 00 40 19 01 00 00 DC 4A
01 00 00 90 5F 01 00 00 00 08 28 6E 00 00 00 2C C9 00 00 01
F8 0B 01 00 02 80 38 01 00 03 90 5F 01 00 04 F4 91 01 00 05
Does it have a slider for HBM memory (actual HBM memory not the crap VDCCI slider AMD uses). Side note, has anyone tried editing HBM memory in PP table in registry? (its the one thats listed as 1350 mv for Vega 64/FE)Originally Posted by micjohben
Has anyone tried the new Afterburner 4.4.0.Beta 19 which now has Vega voltage controls? I'm not sure it works properly with the blockchain drivers however the voltage sliders wouldn't activate for me no matter what type of voltage change model in the preferences.
If I add the latest crimson drivers then the softpowerplay table mod stops working,
Has anyone got an equivalent or alternative for the newest drivers?
It just has the one voltage slider which on my machine wouldn't activate.
If you have Vega 64/FE search for "46 05" and change it to "78 05"Originally Posted by micjohben
I tried with latest crimson drivers and the blockchain drivers and no dice.
back to softpowerplaytable and Noverdrivetool to fine tune.
Where is the voltage for mem overrides in the table? I know setting the mem in the table for P3 to 850mv will let me undervolt the P7 State 1200 to 800mv on the Core clock but when I look at HWInfo I can still see the memory using 1.3 odd V.
Very odd but par for the course with AMD. Nothing works at first glance. They are a bit like maintaining an classic italian sportscar.
They occasionally are very fast on the road, but run hot and spend more time in maintenance and tinkering stage than actually bloody driving the things...![]()
Thanks for the pointer, I'll try undervolting as thats my intention, but I'll make the changes and report back if it works.
IIRC I did a VBIOS with UEFI/GOP module disabled early on in thread. Jstefanop flashed and card did not post, again down to how the "security feature" on VEGA detects unsigned modified VBIOS and blocks GPU post.Originally Posted by Vento041
Guys did someone try to disable/remove UEFI image on the vaga card bios, flash it to force to use only the legacy rom?
Originally Posted by Leons
Hello, sorry my English (Google Translator).
I have a VEGA56 and if you want I can try it, but you should disable UEFI from my bios because I'm not sure to do it properly.
Vega1056left.zip 136k .zip file
@buildzoid
Hell manOriginally Posted by hellm
@buildzoid
hellm like hell + m, yes; it is just birthplace and gender. thanx for clearing that up.![]()
On Polaris, it is pretty easy to overvolt; and it sticks. if you do nothing else than switch to manual voltage. if you know what clockrate you want, you can also do that with softpowerplay. Softpowerplay clockrates overrides the BIOS clockrates, only the voltages need manual voltage setting (since 17.4.1). If you want to adjust clocks for benches and change voltages, you can not use wattman as usual.. so, yes, clunky.
other than that, great vid.![]()
See I tried to set clocks through afterburner when testing 1.3 vcore in the PPtable and it had the exact same problems as Wattman.Originally Posted by hellm
@buildzoid
Yes, u gave me that link.Originally Posted by mynm
Hell man, I remenbert to use the PP_PhmSoftPowerPlayTable before than you
, you know, and since my first post. But it doesn't matter, you did a very good job explaining it for vega and polaris
I think it's better to get the PP_PhmSoftPowerPlayTable with Afterburner like I explained here: http://www.overclock.net/t/1609782/watttool-a-simple-tool-that-combines-overclocking-with-vrm-monitoring-tweaking-for-rx-400-series/90#post_25504298
I remember as well, to explain here for polaris gpus: http://www.overclock.net/t/1629717/mod-sapphire-rx-480-nitro-oc-to-sapphire-rx-580-pulse/10#post_26104362 , what buildzoid names "voltage floor" here:.
mynm is just an abbreviation of literaly "my name".![]()
Yes, you can't use other oc tools. WattTool for Polaris works, it uses the AMD ADL API..Originally Posted by buildzoid
Also temperature limits are BIOS side. VEGA Liquid BIOS + Air power play will still shut down at 75C regardless of the power play table settings.
I don't have any working polaris cards left and honestly I still don't see the point of going through the power play table on cards where BIOS modding works and software has much fewer restrictions.
Ok wellOriginally Posted by hellm
Yes, u gave me that link.![]()
Afterburner might also be able to do that on Vega, with the latest beta; or in the near future. i mentioned that some time ago.. also your name, but i don't think it was in this thread. some must have known what is behind that "extend oc limits" thing in afterburner, i never wanted to leave the impression it was made by me or something... but i got mentioned in buildzoid vids 3 times now.![]()
VEGA Liquid BIOS + modded liquid SoftPowerPlay should do the trick?
The 4xx Polaris cards have this signing thing, u can't mod them too; or you have to patch the driver. But since you can make a 470/80 now look like a 570/80, and the 5xx doesn't require a signed BIOS, yes, no real use for other cards.
