I've been running 3.6GHz @ 1.4625v for over a year now, I left prime95 running for 48 hours with no problem.
Recently it's been coming up with an error on the 4th core after about 10 minutes of use, temps never going above 64~C
When I bump the voltage up the next increment to 1.475v, it runs for longer with no errors, but gets an error after about 25~ mins because temps hitting 76~C
I did some testing before and prime95 only produced errors when going above 70c, even if it is 100% stable at lower temps, 70c seems to be the unstable threshold.
However I have a question.
The 4th core is the only one producing an error, so if at 3.6GHz @ 1.4625v was previously stable, perhaps the error is because it's too hot?
If I run prime95 with 1 thread, manually set the affinity to the "problem core" and stress test it, the temps don't go above 51C because the other 3 cores are idle, and it produces no errors
Does this mean it is stable and just produces an error because it's too hot?
