1 - 8 of 8 Posts
Does the amount of time Prime 95 blend test runs reflect stability? Such as if it fails after 5 mins your computer is more stable than when it failed at 1 min?
Primed for 4 hrs = reasonably stable
Primed for 8 hrs = everyday-use stable
Primed for 12+hrs = 24/7 stable
blend or torture, either one.
Blend covers all the bases...torture is well...torture.
Discussion Starter · #6 ·
Blend is under the torture test. Also is it ok to run things like msn and aim or should I close everything when running prime95?
you can run anything you want while priming. its best to keep use to a minimum though while priming, you want the crash (if any) to be hardware related, and not software related.
1 - 8 of 8 Posts
