1 - 7 of 7 Posts
Hi,
I've been using Prime 95 29.4 for testing the CPU & RAM - Also other versions have now been downloaded.
29.4 shows no mention of AVX / AVX2 instructions - In 29.8 there is a check box for AVX AVX2 & AVX 512 to disable or not.
Does 29.4 actually use AVX / AVX 2 to stress the CPU as part of its testing?
There is also a text file "prime" which shows no mention of AVX within the text file
p95v294b8.win64 <<<< this is the version currently being used (29.8)_I do have but not used yet
Just looking at this a little more closely doing a RAM / CPU clock (7700 K) & DRAM - DRAM is the main focus here -
Any info helpful - Thanks
I do have two versions of Asus Real Bench - Also have OCCT - & - Mem Test 86
MemTest86 is being used actively with P95
P95 27.7 - 29.4 have AVX enabled by default and can only be disabled by modifying the text file. Later versions give you the option in the GUI.
Reactions: TwoCables
Not new to Overclock.net
Edit: nevermind. :)
Reactions: T.Sharp
temperatura stanza ideale 22 gradi...tana miseria u si stciopa ad cheld
Hi, it's good to know this is covered as it's the version I've been using - 🙂
1 - 7 of 7 Posts
