1 - 3 of 3 Posts
Go to Options => Torture Test => 1) Click Blend 2)Then click Custom => Then choose the amount of RAM to be used during the test.
As you may well know, Prime 95 has to run for 6+ hours to check stability.
Thus, I recommend OCCT.
(Click on HTTP or FTP to download; they're written by occt version 0.91.)
OCCT only needs to be run 30 min. for stability and 1 hour for the ultimate stability.
ok just downloaded ready to run
ill let ya know
1 - 3 of 3 Posts
