1 - 3 of 3 Posts
I'm currently working on a P4 socket 478 presscot 2.8Ghz, which is of course - a single core.<br />
<br />
For some reason when opening speedfan, it shows two bars for the processor usage status, as if there were 2 cores. When stressing using prime95 only one bar seems to reach full load(50%), again like this is a dual core system.<br />
<br />
Windows task manager verifies this as well - only 50% load on the processor.<br />
<br />
I'm running prime95 large ffts test.<br />
<br />
why is this happening?
You prolly have Hyper-Threading enabled, wich tricks the pc in letting it think there are 2 cores, by emulating the other core.<br />
<br />
You can disable this in BIOS or just run 2 instances of Prime95. I wouldn't disable it though, because you may have a little better performance while it's enabled.
Reactions: GGuyZ
thanks <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 3 of 3 Posts
