1 - 7 of 7 Posts
Originally Posted by m|dg3t
What exactly do I run to test the stability of the CPU?
Large FFTs seem to pick up instability well.
Thanks, will it end or do I just stop it?
It will keep running, providing there are no errors
Yea. Try and run it while you're gone somwhere, 12HR is the best then you know ur system's stable.
Choose In place large FFT's for maximum heat and power consumption. This will stress your cpu to the fullest.
Blend test more RAM than the CPU.
1 - 7 of 7 Posts
