1 - 7 of 7 Posts
Hi Guys
I've got a question about running dual primes for a dual core system.
I run two instances, setting affinity for each instance then go to options, torture test and then custom........what settings should I put in the custom options?
I usually split the ram over both instances and leave the rest as standard, is this correct?
Cheers
I tend to run 1 instance of Prime on the weaker core of my 3800X2.
I dont bother testing much of my memory, as Im checking my CPU, not memory, for stability. I make sure my memory is under stock clock.
That is the best way until you realise that your dual core 4400 is just 2 Athlon 3700's stuck together, and you notice that one core always fails before the other (in my case, Core 1).
1 - 7 of 7 Posts
