1 - 4 of 4 Posts
I'm looking to use both rigid (PETG) and flexible tubing in a build soon. I'm curious about what fittings I can use with the 3/8" ID 1/2" OD LRT tubing. The Primochill website has an empty page for flexible fittings.
Ideally, I'd like to use the same fittings everywhere. If I get Primochill rigid fittings, would they also work with their LRT tubing?
Rigid fittings will only work with rigid tubing. And regular compression fittings will only work with flexible tubing. If you are using 3/8 ID 1/2 OD flexible Primochill Advanced LRT tubing, you'll need to use 3/8 ID 1/2 OD fittings. Recommended fitting brands are Bitspower, Monsoon, EK, Enzotech. Stay away from Alphastool fittings (particularly their rotaries).
i have ek compression fittings size 3/8 ID 1/2 OD , and i use primochill LRT tube at the same
size of the fitting which is 3/8 ID 1/2 OD , but you have to put the primochill tube in warm
water to make it little softer .
1 - 4 of 4 Posts
