As titles states, is it possible, is it worth it if your broke and you have 2, how should I go about doing my shenanigans?
I want the thing that is in the link, but instead of just the green and black wires, I want them all.Originally Posted by Superpuperdudle;15329879
Splicing them? If you mean running the at the same time then its been done, i did it at one point. Just jump the second PSU with a paperclip when you need to run it.
EDIT - Or get this
http://www.frozencpu.com/products/5637/cpa-167/Lian_Li_Dual_Power_Supply_Adapter_Cable.html
OHHHHHH, you want to run the 2 PSU's as one, combining all their lines? It would help if i knew why, since this wont give any more voltage to the motherboard and will only destroy it shortly after.Originally Posted by MR KROGOTH;15329888
Im already doing two.
What I need to know is how to merge the 12v, 5v and 3.3v lines to be a success.
Because mine cant supply enough amperage, and I simply want to give it a little "Boost".Originally Posted by Superpuperdudle;15329924
Originally Posted by MR KROGOTH ![]() Because mine cant supply enough amperage, and I simply want to give it a little "Boost". I dont want to combine voltage. Only amperage. |
