1 - 3 of 3 Posts
Okay, every time I open a folder it opens it's properties, and my keyboard randomly stops working at the same time too. This is the first time it has happened and this a new computer (1 month old). It is running Windows 8 perfectly and I have rebooted it several times, and the problem doesn't go away.
I have tried
  • rebooting the system
  • scanned it for viruses (avast antivirus) (none)
  • new keyboard/mouse
  • System Restore
It is running Windows 8 x64
Computer Specifications:
  • CPU: Intel i7 3770k
  • Motherboard: Asus Sabertooth Z77
  • Graphics Card: Nvidia GTX680
  • HDD: 2TB Seagate Barracude, 120GB Samsung 830 SSD
I am really worried about this problem and I can't find a solution.
Did you do a clean install of Windows 8 or upgrade?
Initially I would check the mouse settings in control panel and verify the option to switch the primary and secondary keys isn't enabled. After that I would see if anything is enabled under Ease of Access Center > Make the mouse easier to use.
1 - 3 of 3 Posts
