Hi,
I have a 120mm fan attached to my heat sink, which runs at a maximum of 2700 RPM all the time. I am on an Abit IP35 Pro motherboard. I've tried adjusting the BIOS settings and I've used the UGURU software a few weeks ago. The UGURU software worked. I basically went to the "Fan EQ" setting and chose "Quiet Mode" which had the following settings:
40 C Temp , Voltage Low 30%
75 C Temp, Voltage High 100%
For some reason it stopped working and my fan is noisy as hell running at 2700RPM. The CPU Temp reading is 27.
Does anyone know what the problem is?
Thanks..
Thanks..
