Originally Posted by J3r3my
This is in the wrong section.
Take it easy on the new guy
I moved it for you. In the future make sure it is in the correct section. Also make sure your titles are more descriptive.
If it is a P4 2.4 it would be good to include that in the thread title. That way people with 2.4s would jump right in the thread
As to your problem. I am willing to bet it has to do with not being able to lock your PCI bus. you see when you overclock your FSB you end up overclocking your PCI bus and your AGP bus as well. Doing this ends up causing curruption in your video and your hard drives. The end result is usually some data loss on your hard drive. OR if you have not gone too far just some crazy errors in windows. Or a loss of internet and stuff like that. If you can you would be wize to upgrade to a OC friendly Motherboard.
