I am using a BFG GeForce 6800 GT (AGP version). I am using 71.24a Alpha Drivers (Xtreme G). Wolfenstein would not start, because it crashes on Unsupported Marker Type.
Enemy Territory and Multiplayer of RTCW works fine.
Screen Shot of Error:
Please help me out!
Wolf 1.32 win-x86 May 1 2002
----- FS_Startup -----
Current search path:
C:\\PROGRA~1\\RETURN~1\\main\\sp_pak4.pk3 (21 files)
C:\\PROGRA~1\\RETURN~1\\main\\sp_pak3.pk3 (14 files)
C:\\PROGRA~1\\RETURN~1\\main\\sp_pak2.pk3 (232 files)
C:\\PROGRA~1\\RETURN~1\\main\\sp_pak1.pk3 (1342 files)
C:\\PROGRA~1\\RETURN~1\\main\\pak0.pk3 (4775 files)
C:\\PROGRA~1\\RETURN~1/main
6384 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\\WINDOWS\\system32\\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created [email protected],0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...101 PFDs found
...hardware acceleration found
...PIXELFORMAT 9 selected
...creating GL context: succeeded
...making context current: succeeded
Initializing OpenGL extensions
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_env_add
...using WGL_EXT_swap_control
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...WGL_3DFX_gamma_control not found
...GL_ATI_pn_triangles not found
...ignoring GL_EXT_texture_filter_anisotropic
...using GL_NV_fog_distance
GL_VENDOR: NVIDIA Corporation
GL_RENDERER: GeForce 6800 GT/AGP/SSE2
GL_VERSION: 1.5.3
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(32-bits) Z(24-bit) stencil(8-bits)
MODE: 3, 640 x 480 fullscreen hz:60
GAMMA: software w/ 0 overbright bits
CPU: Intel Pentium III
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_NEAREST
picmip: 1
picmip2: 2
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: enabled
compressed textures: enabled
ATI truform: disabled
NV distance fog: enabled
Fog Mode: GL_EYE_RADIAL_NV
Initializing Shaders
...loading 'scripts/ai.shader'
...loading 'scripts/alpha.shader'
...loading 'scripts/blacksmokeanim.shader'
...loading 'scripts/blacksmokeanimb.shader'
...loading 'scripts/characters.shader'
...loading 'scripts/clipboard.shader'
...loading 'scripts/common.shader'
...loading 'scripts/cursorhints.shader'
...loading 'scripts/decals.shader'
...loading 'scripts/eerie.shader'
...loading 'scripts/expblue.shader'
...loading 'scripts/explode1.shader'
...loading 'scripts/fijets.shader'
...loading 'scripts/firest.shader'
...loading 'scripts/flamethrower.shader'
...loading 'scripts/funnel.shader'
...loading 'scripts/gfx.shader'
...loading 'scripts/heat.shader'
...loading 'scripts/lights.shader'
...loading 'scripts/liquid.shader'
...loading 'scripts/maxx.shader'
...loading 'scripts/menu.shader'
...loading 'scripts/metal.shader'
...loading 'scripts/models.shader'
...loading 'scripts/netest.shader'
...loading 'scripts/oldwolf.shader'
...loading 'scripts/organics.shader'
...loading 'scripts/particle.shader'
...loading 'scripts/q3view.shader'
...loading 'scripts/sfx.shader'
...loading 'scripts/signs.shader'
...loading 'scripts/skin.shader'
...loading 'scripts/sky.shader'
...loading 'scripts/solo.shader'
...loading 'scripts/surfaces.shader'
...loading 'scripts/terrain.shader'
...loading 'scripts/test.shader'
...loading 'scripts/twiltb.shader'
...loading 'scripts/twiltb2.shader'
...loading 'scripts/ui.shader'
...loading 'scripts/ui_hud.shader'
...loading 'scripts/ui_notebook.shader'
...loading 'scripts/ui_wolf.shader'
...loading 'scripts/viewflames.shader'
...loading 'scripts/walls.shader'
...loading 'scripts/z_light.shader'
----- finished R_Init -----
------- sound initialization -------
Initializing DirectSound
locked hardware. ok
----- Sound Info -----
sound system is muted
1 stereo
32768 samples
16 samplebits
1 submission_chunk
22050 speed
0x95c8060 dma buffer
No background file.
Sound memory manager started
Parsing menu file:ui/main.menu
r_rmse of 0.000000 has saved 12kb
Parsing menu file:ui/setup.menu
Parsing menu file:ui/controls.menu
Parsing menu file:ui/cdkey.menu
Parsing menu file:ui/system.menu
Parsing menu file:ui/options.menu
Parsing menu file:ui/credit.menu
r_rmse of 0.000000 has saved 204kb
r_rmse of 0.000000 has saved 252kb
r_rmse of 0.000000 has saved 264kb
Parsing menu file:ui/connect.menu
Parsing menu file:ui/quit.menu
Parsing menu file:ui/vid_restart.menu
Parsing menu file:ui/snd_restart.menu
Parsing menu file:ui/rec_restart.menu
Parsing menu file:ui/default.menu
Parsing menu file:ui/error.menu
Parsing menu file:ui/serverinfo.menu
Parsing menu file:ui/quitcredit.menu
Parsing menu file:ui/resetscore.menu
Parsing menu file:ui/buy_pop.menu
Parsing menu file:ui/multiplayer_pop.menu
Parsing menu file:ui/play.menu
Parsing menu file:ui/load.menu
Parsing menu file:ui/mods.menu
Parsing menu file:ui/briefing.menu
UI menu load time = 1072 milli seconds
Parsing menu file:ui/ingame.menu
Parsing menu file:ui/ingame_controls.menu
Parsing menu file:ui/ingame_options.menu
Parsing menu file:ui/ingame_system.menu
Parsing menu file:ui/ingame_leave.menu
Parsing menu file:ui/ingame_player.menu
Parsing menu file:ui/ingame_load.menu
Parsing menu file:ui/ingame_save.menu
Parsing menu file:ui/in_vid_restart.menu
Parsing menu file:ui/in_snd_restart.menu
Parsing menu file:ui/in_rec_restart.menu
Parsing menu file:ui/notebook.menu
Parsing menu file:ui/clipboard.menu
Parsing menu file:ui/bookz.menu
Corrupt JPEG data: bad Huffman code
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Unsupported marker type 0x44
Please help me out!
