1 - 12 of 12 Posts
so I got my new ultra-d today...come to find out, its 4pin 12v....with no room to use 6pin ( which is what my psu is ) what do i do????
When I just have the 24pin power connect in, and power up, my cpu fan, and stuff spins.....
Your PSU should have two connectors..one 4 and one 6. 6 is for video cards. 4 is for the mainboard.
i found out the hard way that the 6 pin is PCI-E
got my new rig all built and saw i had a 8-pin 12v on my mobo so i tried the 6 pin in it but it wouldnt boot. took a day to realise that 6 pin goes in my VGA.
D'oh!
suprised it didnt damage my mobo some how
D'oh!
DOH! Lucky for you, the 6 pin and the 4 pin are nearly identical in voltage.
Discussion Starter #8
My motherboard doesn't have a 4pin..it has a 6, and an 8....on my motherboard before, i used the 8pin..just had 4 of the pins not in, and it worked fine..so what do i do now? get a new psu?
If you have one solid 8 pin connector? You can use a hacksaw and cut the 8 pin molex into two 4 pin connectors. then plug in one block of 4. Just pay careful attention to the alignment of the locking tab. You wouldn't want to plug that in backwards.
OR, get a PSU with 4 pin connectors.
Reactions: JeremyS
Discussion Starter #11
that worked. thank you a lot....i think I love you.
Check out cyberguys for a 8-pin to 4-pin converter. I looked briefly through their site and I did find a 4-pin molex to 4-pin motherboard connector that would solve you problem, and without a hacksaw. Cyberguys have a lot of odd converters that are hard to find.
1 - 12 of 12 Posts
